Apr 11, 2022Guru - Experienced User
New - RBR50 / RBS50 Firmware Version 2.7.4.24 Released
New Features and Enhancements:
Admin password brute force attack prevention
Admin password strength enforcement
EU data analytics opt-out
Bug Fixes:
The backup config file i...
lvangent
Apr 28, 2022Guide
Updated my RBR50 yesterday to V2.7.4.24 and ran into major issues.
PPPoE no longer working
Could not make any changes to PPPoE settings.
Ended up erasing RBR50 both through web interface (did not work), hard reset button.
Managed to get PPPoE back running but there is still on issue.
The moment I turn on traffic meter I loose PPPoE.
Disable traffic meter, PPPoE comes back after a few minutes.
previous version V2.7.3.22 did not have this problem, downgrading to V2.7.3.22.
CD_router_888
May 03, 2022Guide
Hi lvangent ,
Did you enable this function ' Disconnect and disable the internet connection ' in traffic meter ?
- lvangentMay 04, 2022Guide
Hi,
thanks for the suggestion but
No I did not select this as I have unlimited internet quota. I just want to keep track of how much data is download/upload as we have a lot of streaming happening, remote school and working from home.
cheers
- 1-prop-headMay 04, 2022Aspirant
RBR50 + 2 RBS50 sats FW V2.7.3.22
Issuse is that my WIFI network device list contains improper IP address when viewed from the Attached Devices page on the RBR50 web interface.
Network is 10.0.0.x but find duplicate provisioned addresses: ex 192.168.168.100 is there 7 times indicated that is was provided by the RBR50 mostly but also from either of the RBS50's
This condition results in the WIFI network not working at all.
I spent several hours resetting the RBR50 and two RBS50's to factory defaults and then doing a total reinstall and now after less than a day the system has the same duplicate IPs just like it was prior to the reinstall with the above duplicate IPs and non functioning wireless internet.
I will try the new firmware V2.7.3.24 but after looking at the update description feel that this will just be another 5 hours of waisted time.
- FURRYe38May 04, 2022Guru - Experienced User
Please post a screen shot of what your seeing.
What devices do you have connected?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
