Apr 11, 2022Guru - Experienced User
New - RBR50 / RBS50 Firmware Version 2.7.4.24 Released
New Features and Enhancements:
Admin password brute force attack prevention
Admin password strength enforcement
EU data analytics opt-out
Bug Fixes:
The backup config file i...
CrimpOn
May 04, 2022Guru - Experienced User
pgrunwald wrote:
My RBR50 is at v2.7.3.22, showing 'no new firmware version available'
My RBS50 is at v2.7.3.22, showing 'no new firmware version available'
Netgear's firmware update process remains confusing. There seem to be three independent processes going on:
- Netgear publishes new firmware on the support web site. For the RBR50 product, this is at:
https://www.netgear.com/support/product/RBR50.aspx#download
This web page shows that V2.7.4.24 is now available. If customers discover this new version, read the release notes,
and decide to install it on their system, then can download the *.zip files, extract the firmware images, and use the
Manual Update feature to load it on their router and satellites. - At some point, Netgear activates the Automatic Update feature which allows the router to "find" this new firmware and offer to load it. Customers who never look at the firmware update feature will be blissfully unaware of it. This process appears to be "rolled out". My RBR50, for example, continues to report "No new firmware available."
For those who do discover the new firmware, installing it remains optional. - At some point, Netgear has the option to install the new firmware automatically, usually in the middle of the night. Customers who look at the management interface (or the app) may realize, "hey. the firmware updated by itself." Customers who never look at the management interface will remain blissfully unaware that this has happened. This process appears to be "rolled out" over a period of time.
When the Orbi system is behaving strangely, one step that is often recommended is to update the firmware to the latest release. This may be not so much in hopes that it will fix the problem as in the realization that the first thing others will recommend is to update the firmware. Might as well get that out of the way.
In the case of these incorrect IP addresses, I have low expectations that newer firmware will remedy the problem.
Diagnosing this sort of thing is rather technical. My tactic would be to activate the debug option to "Capture LAN\WAN traffic", restart the problem device, save the debug zip file, and then open the file lan.pcap with Wireshark and look for the DHCP assignment to see where it came from.
alokeprasad
May 28, 2022Mentor
"At some point, Netgear has the option to install the new firmware automatically, usually in the middle of the night. Customers who look at the management interface (or the app) may realize, "hey. the firmware updated by itself." Customers who never look at the management interface will remain blissfully unaware that this has happened. This process appears to be "rolled out" over a period of time."
I'm one of those. I was all set to update manually, devoting my Saturday afternoon to it...
I find out that this has happened transparently, I have no idea when.
Took all the fun out of working with 'puters..đ
- FURRYe38May 28, 2022Guru - Experienced User
Do you know what FW version that was on the system before it auto updated?
I find out that this has happened transparently, I have no idea when.Took all the fun out of working with 'puters..đ
- alokeprasadMay 28, 2022Mentor
The one previous to this: 2.7.3.22
