Apr 11, 2022Guru - Experienced User
New - RBR50 / RBS50 Firmware Version 2.7.4.24 Released
New Features and Enhancements:
Admin password brute force attack prevention
Admin password strength enforcement
EU data analytics opt-out
Bug Fixes:
The backup config file i...
jahlewis
Sep 28, 2022Aspirant
After upgrading to V2.7.4.24 on my RBR50 and RBRS50, we've had issues crop up 1-2 times a week where wifi stops working (from no internet while wifi is handshaking/advertising ssid), or where all internet traffic stops (with no issues at the cable router level). I've been rebooting the router and satellite to resolve. I see nothing in the logs indicating an issue. Prior to upgrading to this version, I had no issues. Is anyone else experiencing this? Very frustrating given I work from home and have to deal with these interruptions. This happens to all devices on network (MacOS, Win10, iOS and Roku). How can I troubleshoot? How can I schedule the devices to reboot nightly?
| Hardware Version | RBR50 |
| Firmware Version | V2.7.4.24 |
| GUI Language Version | V1.0.0.423 |
| Operation Mode | Router |
Sep 29, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Hardware Version RBR50 Firmware Version V2.7.4.24 GUI Language Version V1.0.0.423 Operation Mode Router
