Apr 11, 2022Guru - Experienced User
New - RBR50 / RBS50 Firmware Version 2.7.4.24 Released
New Features and Enhancements:
Admin password brute force attack prevention
Admin password strength enforcement
EU data analytics opt-out
Bug Fixes:
The backup config file i...
Oct 18, 2022Guru - Experienced User
Did you factory reset and setup from scratch after applying v.24 FW to the system?
DimitriM
Oct 19, 2022Aspirant
The ISP coax modem is a Compal CH7465LG HGW 3.0 (via Telenet / Liberty Global in Belgium).
No, I didn't perform a factory reset because I preferred not to through the hassle of reconnecting all devices etc.
Thanks
- FURRYe38Oct 20, 2022Guru - Experienced User
If you use same SSID name and password on the wifi settings after you factory reset the RBR, you wifi devices should re-connect automatically to the system. Even the RBS will reconnect.
