Feb 23, 2023Guru - Experienced User
New - RBR50 / RBS50 Firmware Version 2.7.5.4
Bug Fixes: 02/23/2023
This firmware provides the following bug fixes:
Various Armor bug fixes
Various SPC (Smart Parental Control) bug fixes
Security Fixes:
This firmware addresses secu...
- Mar 23, 2023
I recommend a power OFF the the RBR and RBS for 1 minute then back ON with the RBR first then RBS.
Should be fully synced after this.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Jeffgear
Feb 23, 2023Virtuoso
Wow I look forward to trying this but perhaps over the weekend to avoid bricking my system when I need it operational for remote working today and movie night!
It would be nice to have the Armor issues finally resolved. It must have been nearly a year the Armor issue appeared but I guess they were keen to exhaustively test it rather than release a version and cause mayhem as per a time last year on some models.
I see there’s no new update for the outdoor model RBS50Y which remains on a different firmware stream to the one I’m on anyway and that hasn’t had an update for a long time to stay in step with the RBR/RBS updates. I hope it remains compatible once my RBR and RBS are on the latest version.
I’m guessing we may see an Orbi app update as well.
