Feb 23, 2023Guru - Experienced User
New - RBR50 / RBS50 Firmware Version 2.7.5.4
Bug Fixes: 02/23/2023
This firmware provides the following bug fixes:
Various Armor bug fixes
Various SPC (Smart Parental Control) bug fixes
Security Fixes:
This firmware addresses secu...
- Mar 23, 2023
I recommend a power OFF the the RBR and RBS for 1 minute then back ON with the RBR first then RBS.
Should be fully synced after this.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
KevinLiT
Feb 23, 2023NETGEAR Moderator
Hello punkorambo,
Welcome to the NETGEAR Community!
SPC is NETGEAR Smart Parental Controls, this feature is used to manage access and implement additional access controls to your network. With NETGEAR Smart Parental Controls (SPC) lets you monitor your children's online activity. You can restrict access to adult content and harmful websites. You can also create different profiles with customized access rules for each child in your family. With SPC Premium, you can set Internet access schedules and time limits, and send your children screen time rewards for good behavior.
Please navigate to the link below for more information on NETGEAR Smart Parental Controls Premium:
Best,
Kevin
Community Team
Jeffgear
Feb 24, 2023Virtuoso
Updated my RBR and RBS without any drama but there’s no new firmware for the outdoor variant of the satellite. It seems to be still compatible on v2.7.4.12 with the RBR and indoor RBS on the new v2.7.5.4 firmware. I guess they have stopped supporting the outdoor unit and it may eventually become incompatible as the RBR updates.
The Orbi app doesn’t take as long to refresh the Network Map when clicking on the satellites for their details which is an obvious improvement. And I notice the app has had an update as well to 2.24.0.44 and seems stable at connecting locally and remotely.
However and somewhat frustrating, despite the release note saying it has fixed some Armor bugs, the same bugs I have raised for nearly a year now are still occurring: it thinks my iOS devices are unprotected despite them running the Bitdefender app with the VPN active, and the Armor feature in the Orbi app reports that notifications are disabled when they are enabled. Both these false positives result in the security score being reported in the low 80s as I have 4 iOS devices that it thinks are unprotected. I tried disabling Armor in the Orbi app and re enabling to force the RBR to refresh. And logging out the Bitdefender app on an iOS device and logging back in to setup the VPN again, but neither has forced a reconciliation with the Armor Security feature in the Orbi app.
- KevinLiTFeb 24, 2023NETGEAR Moderator
Hello Jeffgear,
Thanks for that information on the most recent update!
I understand that you disabled Armor on your Orbi app to refresh your router. Please try to reboot your RBR50 after you disable Armor through the app.
(Note: A factory reset may be required after disabling Armor for changes to take place.)
Please keep us informed on the progress of this issue!
Best,
Kevin
Community Team
- JeffgearFeb 24, 2023VirtuosoHi Kevin
I tried again. I disabled Armor in the Orbi app. Logged out of Bitdefender app on my iOS device. Rebooted the router and satellites. Re enabled Armor. Logged into Bitdefender and setup the VPN. Checked Orbi devices and my iOS device entry and Orbi still thinks it is unprotected and thinks I need to install Bitdefender. The security score has gone up to 85 as it thinks notifications are now enabled. It does this and at some point will drop the score when it thinks notifications are disabled.
I won’t try a factory reset at this stage as I tried that a few months ago at the advice of Support as a fix for this Armor ios issue and it made no difference. I don’t really want to waste the time again as the internet is in use at home, and it’s a certain fix and not a hopeful try and see suggestion as a last resort. I think there’s a long running unresolved bug with Armor and iOS devices. I heard some Android were experiencing this as well so it will be good to hear from any Android users who I’ve updated their router to this latest version.- JeffgearFeb 24, 2023VirtuosoOddly and not surprisingly the score has dropped as it now thinks notifications are disabled and it’s now thinking a web cam should have Bitdefender installed so adds that to its list of eligible iOS devices . It usually drops the camera from its list of eligible devices for protection after some period of reconciliation, I think previously this was a day or so later.
