Feb 23, 2023Guru - Experienced User
New - RBR50 / RBS50 Firmware Version 2.7.5.4
Bug Fixes: 02/23/2023
This firmware provides the following bug fixes:
Various Armor bug fixes
Various SPC (Smart Parental Control) bug fixes
Security Fixes:
This firmware addresses secu...
- Mar 23, 2023
I recommend a power OFF the the RBR and RBS for 1 minute then back ON with the RBR first then RBS.
Should be fully synced after this.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Slychlander
Mar 23, 2023Aspirant
Hi i managed to force the update by selecting the FW file in the browse field and hitting update - my error i thought i needed to see a description and check box for the RBR50 - you don't need this just do as above. Hopefully the satellites will all recover I will restart them too. Many thanks to all the technical and helpful people on here case closed for now!
Mar 23, 2023Guru - Experienced User
Enjoy. 📡
