Feb 23, 2023Guru - Experienced User
New - RBR50 / RBS50 Firmware Version 2.7.5.4
Bug Fixes: 02/23/2023
This firmware provides the following bug fixes:
Various Armor bug fixes
Various SPC (Smart Parental Control) bug fixes
Security Fixes:
This firmware addresses secu...
- Mar 23, 2023
I recommend a power OFF the the RBR and RBS for 1 minute then back ON with the RBR first then RBS.
Should be fully synced after this.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
dougwright
Mar 25, 2023Aspirant
Hello,
I was upgrading my RBR50/RBS50 from 2.7.4.24 to 2.7.5.4. As per the documentation I attempted to manually upgrade the satellite first. This seemed to go well, but after the satellite restarted it still reported its version as 2.7.4.24. I tried to upgrade it a second time, but on that attempt is said I was trying to upload the same firmware version. Moving on to the router, it upgraded to 2.7.5.4 fine.
Both the router and satellite appear to be working correctly, but I'm not sure what to do with the satellite now with it still reporting it's at 2.7.4.24 and saying I'm trying to upload the same version if I attempt to upload 2.7.5.4.
Any assistance would be appreciated.
Thanks
Mar 25, 2023Guru - Experienced User
And be sure to use the RBS web page to send the FW file directly to the RBS, and not the RBRs web page.
dougwright wrote:
Hello,
Thanks
