Feb 23, 2023Guru - Experienced User
New - RBR50 / RBS50 Firmware Version 2.7.5.4
Bug Fixes: 02/23/2023
This firmware provides the following bug fixes:
Various Armor bug fixes
Various SPC (Smart Parental Control) bug fixes
Security Fixes:
This firmware addresses secu...
- Mar 23, 2023
I recommend a power OFF the the RBR and RBS for 1 minute then back ON with the RBR first then RBS.
Should be fully synced after this.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Raymond3764
Jun 22, 2023Tutor
Hello,
Can anyone please help me out.
I just udated my Satellite and Router (RBS and RBR50) to the latest firmware.
Recently, without me doing anything my iPhone and iPad won't connect to the router. It says "no network", though it is connected.
After updating the firmware this is still the case.
When I connect to the Guest WiFI, it connects properly.
A few firmware updates ago no problems (I forgot that version).
Can anyone help me out which firmware update is the best/stable one I can use or what else I need to do to get connected properly?
- KevinLiTJun 22, 2023NETGEAR Moderator
Hello Raymond3764 ,
Welcome to the NETGEAR Community!
I understand that you are not able to access your Orbi network using your iPhone and iPad. Both of these operating systems are based on iOS and IPadOS and have a feature called Private IP. The main purpose of this feature is to hide your IP address from online trackers. However, in some cases, it can cause network compatibility issues. If the iPad and iPhone are the only devices that are not able to access the network please consider turning off the "Private IP address" feature.
Please follow the directions listed below to turn off the Private IP address:
Open "Settings"
"Wi-Fi"
Select the "i" icon next to your connected network
Toggle off "Private Wi-Fi Address"
Best,
Kevin
Community Team- Raymond3764Jun 22, 2023Tutor
Thank you for your reply.
it seems to work.
Never thought about this.Does this depend on what iOS version I have? Other Apple products seem to have no problem.
Hello Raymond3764,
You are very welcome!
This issue has been reported for some users while other users experience no issues using their iOS devices on their Orbi network.
Best,
Kevin
Community Team
