Feb 23, 2023Guru - Experienced User
New - RBR50 / RBS50 Firmware Version 2.7.5.4
Bug Fixes: 02/23/2023
This firmware provides the following bug fixes:
Various Armor bug fixes
Various SPC (Smart Parental Control) bug fixes
Security Fixes:
This firmware addresses secu...
- Mar 23, 2023
I recommend a power OFF the the RBR and RBS for 1 minute then back ON with the RBR first then RBS.
Should be fully synced after this.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
pdeethardt
Jul 28, 2023Apprentice
I'm probably much newer to the Orbi world than the majority of posters here, having purchased a system in 2020, but I believe that this is the first firmware update that hasn't showed up in the web interface and app interface since I've had my system. I'm usually a person who installs firmware updates as soon as they are released, but after a nearly failed attempt at updating the Orbi firmware several versions back where I needed to use the app to successfully complete the update, I've since waited until the update is also showing up in the web/app interfaces before doing a manual update. I'm a little leery of updating manually to this version as I don't have a fallback if something goes awry. I've also made the assumption that when a firmware update shows up in the web/app interface it's been installed enough times where Netgear has determined it to be stable enough, and has decided to release it to the masses. Whether or not that's correct, I have no idea.
