Feb 23, 2023Guru - Experienced User
New - RBR50 / RBS50 Firmware Version 2.7.5.4
Bug Fixes: 02/23/2023
This firmware provides the following bug fixes:
Various Armor bug fixes
Various SPC (Smart Parental Control) bug fixes
Security Fixes:
This firmware addresses secu...
- Mar 23, 2023
I recommend a power OFF the the RBR and RBS for 1 minute then back ON with the RBR first then RBS.
Should be fully synced after this.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
pdeethardt
Jul 28, 2023Apprentice
I'm probably much newer to the Orbi world than the majority of posters here, having purchased a system in 2020, but I believe that this is the first firmware update that hasn't showed up in the web interface and app interface since I've had my system. I'm usually a person who installs firmware updates as soon as they are released, but after a nearly failed attempt at updating the Orbi firmware several versions back where I needed to use the app to successfully complete the update, I've since waited until the update is also showing up in the web/app interfaces before doing a manual update. I'm a little leery of updating manually to this version as I don't have a fallback if something goes awry. I've also made the assumption that when a firmware update shows up in the web/app interface it's been installed enough times where Netgear has determined it to be stable enough, and has decided to release it to the masses. Whether or not that's correct, I have no idea.
Jul 28, 2023Guru - Experienced User
If you have prior versions of FW files on hand then you'll have something to fall back on.
If you follow the suggestions seen in the first post, you'll be fine.
Update the RBS first then RBR lastly.
Recommended to use a ethernet connected PC to the RBR.
Use the RBS web pages to send the FW file.
I recommend after the RBS and RBR have completed the FW update, power everything OFF for 1 minute then back on with the RBR first then RBS. Then observe.
- alokeprasadOct 27, 2023Mentor
Hi all,
It has been a while. My RBK50 (one RBR50, two RBS50) on ver. 2.7.4.24 has been working fine for many months.
My satellites dropped off yesterday. I had to power-cycle them to get them back on the network.
Checking (via the web interface), I find that ver. 2.7.5.4 has been out for 8 months!
However, the web interface shows "No new firmware version available". I know it sometimes take a while for the updates to show up on the servers.. but 8 months!?I typically use Chrome, but also have Edge. My Firefox has tons of add-ons like ad and script blockers, so I try to avoid using it for things like this.
Should I manually download and update my RBS's and then RBR? Any gotcha's with this firmware of update process that I should be aware of?
- FURRYe38Oct 27, 2023Guru - Experienced User
Yes, manually RBS first, then RBR lastly.
- alokeprasadMar 02, 2024Mentor
TLDR:
I'm having problems: My satellites have disconnected and won't reconnect.My router updated itself to 2.7.5.4 a few days back without my knowledge or involvement. Probably March 1.
That's when both my satellites disconnected and won't reconnect despite cold boot of the satellites, resync atempts by pressing the buttons or through the web interface. I even removed a satellite from the system and brought it into the same room as the router.. No dice. It tries, I get the solid magenta ring LED on the satellite.. sometimes it gets an amber ring for a few seconds.. then a solid magenta.I don't know if the satellites updated or not, as they are never accessible.
Questions:
Any advice on how to proceed?Are my satellites bricked?
PS: My devices all over the house disconnected. It takes a long time for them to reconnect for the first time, even when supplied with correct password. After that, they connect fine. They are all connected to the router now.
