Oct 28, 2020Guru - Experienced User
New - RBR50 / RBS50 Firmware Version v2.7.1.60 Officially Released
RBR50 / RBS50 Firmware Version 2.7.1.60 (for US Region Only) Security Fixes: Fixes security issues Download Link:. https://kb.netgear.com/000062494/RBR50-RBS50-Firmware-Version-2-7-1-60-for-...
Oct 30, 2020Guru - Experienced User
These are for manual updating currently. It's up to you if you wanna try it.
GMoGoody8
Oct 30, 2020Luminary
Must be an important update for something even though the Release Notes don't really specify. Opened the App this morning and was prompted to update to this version. Fastest that has ever happened.
Loaded through Web Page. I'll keep this channel posted on how it settles in.
- jhoff909Oct 30, 2020Apprentice
2
GMoGoody8 wrote:Must be an important update for something even though the Release Notes don't really specify. Opened the App this morning and was prompted to update to this version. Fastest that has ever happened.
Loaded through Web Page. I'll keep this channel posted on how it settles in.What version were you starting with? Mine's on 2.5.2.4 and I'm not getting promp;ted to update even with manually checking for updates.
