Oct 28, 2020Guru - Experienced User
New - RBR50 / RBS50 Firmware Version v2.7.1.60 Officially Released
RBR50 / RBS50 Firmware Version 2.7.1.60 (for US Region Only) Security Fixes: Fixes security issues Download Link:. https://kb.netgear.com/000062494/RBR50-RBS50-Firmware-Version-2-7-1-60-for-...
Stev3D
Nov 05, 2020Luminary
This update has caused me all sorts of problems with my RBK50 setup (that'll teach me not to wait until it is actually pushed to me -- does Netgear actually test these things, or are we unwitting beta testers?).
Is downgrading to 2.6.1.40 simply a matter of manually installing the firmware?
- FURRYe38Nov 05, 2020Guru - Experienced User
Did you apply and continue to use the orbi system or did you power cycle the system or factory reset anything? Did you apply the Fw update using Orbi app or the RBRs web page?
Yes.
- Stev3DNov 05, 2020Luminary
FURRYe38 wrote:Did you apply and continue to use the orbi system or did you power cycle the system or factory reset anything? Did you apply the Fw update using Orbi app or the RBRs web page?
Yes.
I power cycled both the satellite and the router (at nearly the same time) since the update and after I started seeing problems. My setup is fairly involved, so a factory reset is an option of last resort.
As interested as I am in having the (unspecified!) security fix that was provided by this update, the issues that 2.7.1.60 introduced cause me to wait for the next update (which presumably fix these new bugs).
Thank you for the "Yes." I'll get on the downgrade tonight.
