Oct 28, 2020Guru - Experienced User
New - RBR50 / RBS50 Firmware Version v2.7.1.60 Officially Released
RBR50 / RBS50 Firmware Version 2.7.1.60 (for US Region Only) Security Fixes: Fixes security issues Download Link:. https://kb.netgear.com/000062494/RBR50-RBS50-Firmware-Version-2-7-1-60-for-...
Raekon
Nov 05, 2020Tutor
Just wanted to say that upgrading from 2.5.2.4 to this latest version fixed all my issues. I had unusable wifi that would make my network crash as soon as I saturated my internet bandwidth or I was on too many devices at the same time, now with this update I can download and upload at full speed on as many devices as I want without any issue whatsoever. Manually updated satellite first then router, this is the best firmware I’ve ever used to date.RBR50 1st gen
- FURRYe38Nov 05, 2020Guru - Experienced User
Did you apply and continue to use the orbi system or did you power cycle the system or factory reset anything?
Raekon wrote:Just wanted to say that upgrading from 2.5.2.4 to this latest version fixed all my issues. I had unusable wifi that would make my network crash as soon as I saturated my internet bandwidth or I was on too many devices at the same time, now with this update I can download and upload at full speed on as many devices as I want without any issue whatsoever. Manually updated satellite first then router, this is the best firmware I’ve ever used to date.RBR50 1st gen
- RaekonNov 05, 2020TutorJust downloaded it manually as soon as it was available and did manual update on web browser via WiFi starting from the satellite first. No reboot and no factory reset before or after, worked like a charm without going anything particular for me
- Stev3DNov 05, 2020Luminary
Raekon wrote:
Just downloaded it manually as soon as it was available and did manual update on web browser via WiFi starting from the satellite first. No reboot and no factory reset before or after, worked like a charm without going anything particular for meI'm glad you have had no problems. I have two questions for you: (1) Do you have Access Control enabled? (2) Have you tried the Orbi App to view (and manage) attached devices?
Based on your "worked like a charm" comment, I'll be the answer is "No" to either or both of these (related) questions. I think this update broke this functionality (which matters to many of us).
Cheers!
- --ChuckNov 06, 2020Guide
Applied and continued. No power cycle, no factory reset.
I could not use the iPad app to login to my Orbi. I had to delete and reload the app from my iPad. The app on my Android phone had no problems. I had 2 factor authentication enabled.I now have a 3 trusted devices. Phone, iPad, and a phantom iPad. iPad's private IP is disabled.
FURRYe38 wrote:Did you apply and continue to use the orbi system or did you power cycle the system or factory reset anything?
- FURRYe38Nov 06, 2020Guru - Experienced User
I recommend doing this after FW updates. Full power OFF of the RBS and RBR for one minute. If problems are still experienced, then a factory reset and setup from scratch would be next.
--Chuck wrote:Applied and continued. No power cycle, no factory reset.
- Greg00001Nov 05, 2020Star
This is the first version of firmware since 2.3.5.30 where all my devices show in the app and web page! I'm just thrilled about that! So far so good and the app is working perfectly!
