Oct 28, 2020Guru - Experienced User
New - RBR50 / RBS50 Firmware Version v2.7.1.60 Officially Released
RBR50 / RBS50 Firmware Version 2.7.1.60 (for US Region Only) Security Fixes: Fixes security issues Download Link:. https://kb.netgear.com/000062494/RBR50-RBS50-Firmware-Version-2-7-1-60-for-...
Nov 05, 2020Guru - Experienced User
Did you apply and continue to use the orbi system or did you power cycle the system or factory reset anything?
Raekon wrote:Just wanted to say that upgrading from 2.5.2.4 to this latest version fixed all my issues. I had unusable wifi that would make my network crash as soon as I saturated my internet bandwidth or I was on too many devices at the same time, now with this update I can download and upload at full speed on as many devices as I want without any issue whatsoever. Manually updated satellite first then router, this is the best firmware I’ve ever used to date.RBR50 1st gen
--Chuck
Nov 06, 2020Guide
Applied and continued. No power cycle, no factory reset.
I could not use the iPad app to login to my Orbi. I had to delete and reload the app from my iPad. The app on my Android phone had no problems. I had 2 factor authentication enabled.
I now have a 3 trusted devices. Phone, iPad, and a phantom iPad. iPad's private IP is disabled.
FURRYe38 wrote:Did you apply and continue to use the orbi system or did you power cycle the system or factory reset anything?
- FURRYe38Nov 06, 2020Guru - Experienced User
I recommend doing this after FW updates. Full power OFF of the RBS and RBR for one minute. If problems are still experienced, then a factory reset and setup from scratch would be next.
--Chuck wrote:Applied and continued. No power cycle, no factory reset.
I could not use the iPad app to login to my Orbi. I had to delete and reload the app from my iPad. The app on my Android phone had no problems. I had 2 factor authentication enabled.I now have a 3 trusted devices. Phone, iPad, and a phantom iPad. iPad's private IP is disabled.
