Oct 28, 2020Guru - Experienced User
New - RBR50 / RBS50 Firmware Version v2.7.1.60 Officially Released
RBR50 / RBS50 Firmware Version 2.7.1.60 (for US Region Only) Security Fixes: Fixes security issues Download Link:. https://kb.netgear.com/000062494/RBR50-RBS50-Firmware-Version-2-7-1-60-for-...
glenfaj26
Nov 23, 2020Guide
I tried unzipping the files and all I get is a message "The disc image is corrupted."
Is this update a joke?
- bolingdeNov 23, 2020Guide
You might try downloading again.
I can't say it's a joke but after messing with it I went back to an earlier version. I'll probably keep it on until I decide to replace the orbi with something else.
- --ChuckNov 23, 2020Guide
glenfaj26 @You are assuming that your Your Orbi has the same CPU architecture as your PC.
The disc image will work on Orbi's ARM CPU not on an PC's Intel x86 CPU.- bolingdeNov 23, 2020GuideIt still should unzip. That's just an application. You have to unzip it to load. I don't think they said they were trying to run the image.
- FURRYe38Nov 23, 2020Guru - Experienced User
DO NOT TRY TO UNZIP THE .IMG FILE. This file is already compiled and used by the RBRs web page. Just unzip the .zip file only. The IMG file is the acutal FW file.
glenfaj26 wrote:I tried unzipping the files and all I get is a message "The disc image is corrupted."
