Oct 28, 2020Guru - Experienced User
New - RBR50 / RBS50 Firmware Version v2.7.1.60 Officially Released
RBR50 / RBS50 Firmware Version 2.7.1.60 (for US Region Only) Security Fixes: Fixes security issues Download Link:. https://kb.netgear.com/000062494/RBR50-RBS50-Firmware-Version-2-7-1-60-for-...
BSmithline
Dec 05, 2020Aspirant
What FIRMWARE is correct for the first version of the RBR/RBS hardware
Need to know what is the current version of firmware for the first model of the RBR/RBS Orbi mesh system?
My units are running V2.5.2.4 and when I do a "check" on the Advanced / Administration / Firmeare Update webpage it shows "No new firmware version available".
When I go to the Netgear website and go to the firmware on the RBR50 linked page and download the firmware it shows version "V2.7.1.60" ( RBR50-V2.7.1.60.zip ). Is this the corect version for the first model of the RBR50 hardware?
Dec 05, 2020Guru - Experienced User
Yes and no. If your in the USA region, you can use this. If your outside the USA region, then you should use this version of FW:
If you can use this version as well as it's the next version of FW up from v4.
NG doesn't post more resent version of FW up on there auto update server necessarily at the same time as they post on the web site.
So users need to check the download site as well.
Up to you if you want to upgrade or not. If you choose to manual update, update the RBS first then RBR lastly. After the FW is applied and processed. Power OFF the RBS and RBR for 15 seconds then back ON.
BSmithline wrote:What FIRMWARE is correct for the first version of the RBR/RBS hardwareNeed to know what is the current version of firmware for the first model of the RBR/RBS Orbi mesh system?
- Stev3DDec 05, 2020Luminary
BSmithline, there are two current versions, 2.7.1.60 and 2.6.1.40.
I initially attempted to use 2.7.1.60 and even though I am in the US, all hell broke loose. Scroll up a bit and you will see my trials and tribulations.
I am running the 2.6.1.40 version and things are pretty much back to normal. If you aren't using Netgear's Armor or other security products, you don't need the 2.7 version (that seems to be the differentiator between 2.6 and 2.7).
Good luck!
- FURRYe38Jan 05, 2021Guru - Experienced User
v102 FW files are now posted for users to manually download and manually apply to there 50 series Orbi systems:
Users may skip v70 and v60 version and go directly to v102.
This version is for users in the US Region only.
Enjoy. :smileywink:- glenfaj26Jan 05, 2021Guide
The files in those link are corrupted. It keeps opening up more links. One file says "the disc image file is corrupted" when attempted to open.
