Oct 28, 2020Guru - Experienced User
New - RBR50 / RBS50 Firmware Version v2.7.1.60 Officially Released
RBR50 / RBS50 Firmware Version 2.7.1.60 (for US Region Only) Security Fixes: Fixes security issues Download Link:. https://kb.netgear.com/000062494/RBR50-RBS50-Firmware-Version-2-7-1-60-for-...
Endosmok
Jan 04, 2021Aspirant
So I just took this update (V2.7.1.60) for my RBR50/RBS50 router and satellite. This was a manual upload as neither unit would see any new firmware available (it's set to auto).
After the update, i noticed my port forwarding was no longer working. I only had 3 services (Blueiris, Plex, and my Hopper).
They are still listed there but not longer accessible. I've tried deleting and re-adding them but to no avail.
I also noticed that my UPnP is may be inoperable as well. I cannot reach anything that is LISTED as ACTIVE in my UPNP status. Nor can i access the UPNP to add BlueIris when I tried that method.
Just checking to see what I can do prior to downgrading the firmware. Maybe there's a setting I am missing? but like I said... this occurred immediately after the FW update to 2.7.1.60.
Any assistance is appreciated.
Thanks
Jan 04, 2021Guru - Experienced User
Try updating to v102. Should be seen in the RBRs web page after v60 is loaded.
If you updated to v60, a factory reset and setup from scratch should be performed. Then test your configurations.
v102 is working well for me and others though I can't confirm your portforward configuration.
Endosmok wrote:So I just took this update (V2.7.1.60) for my RBR50/RBS50 router and satellite. This was a manual upload as neither unit would see any new firmware available (it's set to auto).
Thanks
