Oct 28, 2020Guru - Experienced User
New - RBR50 / RBS50 Firmware Version v2.7.1.60 Officially Released
RBR50 / RBS50 Firmware Version 2.7.1.60 (for US Region Only) Security Fixes: Fixes security issues Download Link:. https://kb.netgear.com/000062494/RBR50-RBS50-Firmware-Version-2-7-1-60-for-...
Jan 05, 2021Guru - Experienced User
v102 FW files are now posted for users to manually download and manually apply to there 50 series Orbi systems:
Users may skip v70 and v60 version and go directly to v102.
This version is for users in the US Region only.
Enjoy. :smileywink:
glenfaj26
Jan 05, 2021Guide
The files in those link are corrupted. It keeps opening up more links. One file says "the disc image file is corrupted" when attempted to open.
- FURRYe38Jan 05, 2021Guru - Experienced User
DO NOT attempt to open the .img file after you unpack the .zip file. Just proceed to the RBS or RBS web page and use the FW update web page in the browser to select the .img file from with in the orbi FW udpate page. Then apply. The .img file format is used ONLY by the Orbi RBS and RBR units.
glenfaj26 wrote:The files in those link are corrupted. It keeps opening up more links. One file says "the disc image file is corrupted" when attempted to open.
