RedBatman89
Jul 01, 2019Guide
New 2.3.5.26 for rbk23. Anyone download or get issues yet?
Anyone?
Jul 01, 2019Guru - Experienced User
Seen some posts about it...might search the forum for that FW version string to see for yourself.
KiamaraKid
Sep 18, 2019Aspirant
When I download the software and try to install it I get the message "The disk image file is corrupted" Any ideas? I have tried downloading it again and get the same message.
- FURRYe38Sep 18, 2019Guru - Experienced User
No.
What browser are you using?
Try a different browser.
Be sure to unpack the .zip files before trying to manually update FW.
KiamaraKid wrote:When I download the software and try to install it I get the message "The disk image file is corrupted" Any ideas? I have tried downloading it again and get the same message.
