RedBatman89
Jul 01, 2019Guide
New 2.3.5.26 for rbk23. Anyone download or get issues yet?
Anyone?
mrbyte
Sep 20, 2019Aspirant
i have rbr20 and my pings got much worse. from 20ms to 170ms. I cannot figure out how to fix this.
- FURRYe38Sep 20, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?How are you testing pings? Wired or wireless?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Has a factory reset and setup from scratch been performed since last FW update? Power OFF The ISP modem for 30 seconds then back on then walk thru the setup wizard after doing a factory reset?
mrbyte wrote:i have rbr20 and my pings got much worse. from 20ms to 170ms. I cannot figure out how to fix this.
- mrbyteSep 20, 2019Aspirant
I think I have an issue outside of the orbi atm. I did a ping from cmd and it was good. Not so good from speedtest even though the machine on the wired is getting 10ms and the machine off the backhaul is getting 175ms even though the ping to router is 3ms.
Lets follow up on your new thread post:
https://community.netgear.com/t5/forums/replypage/board-id/Orbi/message-id/70894
