RedBatman89
Jul 01, 2019Guide
New 2.3.5.26 for rbk23. Anyone download or get issues yet?
Anyone?
mrbyte
Sep 20, 2019Aspirant
i have rbr20 and my pings got much worse. from 20ms to 170ms. I cannot figure out how to fix this.
Sep 20, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
How are you testing pings? Wired or wireless?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Has a factory reset and setup from scratch been performed since last FW update? Power OFF The ISP modem for 30 seconds then back on then walk thru the setup wizard after doing a factory reset?
mrbyte wrote:i have rbr20 and my pings got much worse. from 20ms to 170ms. I cannot figure out how to fix this.
