tnadkarni
Jun 17, 2017Star
New beta v1.11.0.8 appears to fix my long time issues
I've now completed an RMA on both my RBR and RBS with Netgear and sent my old ones back. Running the older beta FW they (the new hardware) was just as bad. But Netgear just sent me a few days ago a n...
ktd
Jun 17, 2017Apprentice
Just installed v1.11.0.8 (10 min ago) and can already see big improvements.
But its to early for me to say that anything really is fixed. But it’s seems to be a good start at least. :)
- CurlypawsJun 17, 2017Aspirant
Hi, does it fix the issues with Nest equipment? I had to switch off beamforming and MU-MIMO to keep the Nest equipment connected.
- tnadkarniJun 17, 2017Star
I don't have Nest but I have 3 Ecobee3 thermostats and they are fine. Also I should add, after flashing this FW I turned on everything including MIMO and Beamforming and it's been rock solid with all that stuff on.
- ktdJun 17, 2017Apprentice
I don’t have any Nests so I can’t tell but my wife garage door opener, d-link camera in the garage haven’t had an issue since I updated.
Before the update I almost never couldn’t get the garage door app to show video from the camera.
- TomMacJun 17, 2017Guru
Yes... been running 1.11.0.2 for a while now ( about 3 weeks) ... all my issues are gone.
No Ipad g2/os 935 not android battery drain issues anymore
The final solution is very near IMO.
Weird .2 was a complete disaster for me but .8 has been great so far.
Thanks very much TomMac, tnadkarni and ktd - that sounds very promising. How do you get the beta?
Sens DarrenM a PM.
https://community.netgear.com/t5/user/viewprofilepage/user-id/2257
- KennNYCJun 17, 2017Aspirant
Sounds great. Where did you get the beta firmware?
As per ktd's message, you should send a Private Message to DarrenM to see if you can get the beta firmware:
- Triscb82Jun 19, 2017Initiate
Can you send me a link to download?
