magatoni
Apr 26, 2019Aspirant
New Comcast modem with my orbi
Hi gang. I’m not a tech guy so thank you for reading this. I have an orbi that I have in AP mode with an Ethernet cable to a Comcast gateway (that has the WiFi turned off on the gateway). If the ...
Apr 26, 2019Guru - Experienced User
Depends if the new modem is a modem only or another gateway modem which means it has a built in router and wifi. Stand alone modems are preferred for use with external routers such as Orbi.
