murchman
Dec 12, 2016Apprentice
New Firmware 1.4.0.18 released
Bug Fixes: Fixes the add-on satellite sync issue. Supports the NETGEAR Orbi app. http://kb.netgear.com/000036450/RBR50-RBS50-Firmware-Version-1-4-0-18
genobkk
Dec 14, 2016Star
I did the update without any issues, took less then 5 min, no preformance issues
nlrela
Dec 15, 2016Guide
Got major speed decrease on iOS devices - dropped from about 200 Mbps to less as 20 or sometimes even 10 Mbps (measuered with Netflix / speedtest.net App).
Aynone else experienced this?
Any clue on how to correct this?
- DarrenMDec 15, 2016Sr. NETGEAR Moderator
Hello nlrela
I would try to log into the orbi and go to the wireless settings and try changing the wireless channel and see if that improves the speed. also are your other devices getting the high speeds and didnt experience the loss of speed?
DarrenM
- nlrelaDec 15, 2016Guide
Hi DarrenM
I have changed the channels unfortunately without any positive effect. And all devices are affected.
Only difference is, that I installed FW 1.4.0.18 .....
- JMU1998Dec 15, 2016Luminary
Yes I am noticing that too, iPads, iPhone in my house are lot slower also android phones, tablets. Laptop is fine, hardwired speeds fine. yes did factory reset after updating Firmware and tried different channels only change being Firmware.
If you are willing to test you could try to load .16 back onto the router and check if the issue is fixed so I can report a issue with the latest firmware.
DarrenM
- nlrelaDec 16, 2016Guide
Trying hard to downgrade to .16, but only do see an hourglass for about an hour during uploading FW .... if I refresh or so then nothing has changed and I have to upload again
