murchman
Dec 12, 2016Apprentice
New Firmware 1.4.0.18 released
Bug Fixes: Fixes the add-on satellite sync issue. Supports the NETGEAR Orbi app. http://kb.netgear.com/000036450/RBR50-RBS50-Firmware-Version-1-4-0-18
nlrela
Dec 15, 2016Guide
Got major speed decrease on iOS devices - dropped from about 200 Mbps to less as 20 or sometimes even 10 Mbps (measuered with Netflix / speedtest.net App).
Aynone else experienced this?
Any clue on how to correct this?
JMU1998
Dec 15, 2016Luminary
Yes I am noticing that too, iPads, iPhone in my house are lot slower also android phones, tablets. Laptop is fine, hardwired speeds fine. yes did factory reset after updating Firmware and tried different channels only change being Firmware.
- DarrenMDec 15, 2016Sr. NETGEAR Moderator
If you are willing to test you could try to load .16 back onto the router and check if the issue is fixed so I can report a issue with the latest firmware.
DarrenM
- nlrelaDec 16, 2016Guide
Trying hard to downgrade to .16, but only do see an hourglass for about an hour during uploading FW .... if I refresh or so then nothing has changed and I have to upload again
After the 2nd reboot I succeeded with the downgrade ... will test speeds this weekend
- JMU1998Dec 24, 2016Luminary
I just rolled it back and and did factory reset and input settings manually and no issues, then after 4 days did factory reset upgraded to latest factory reset again and input settings issue has returned so definitely issue with latest firmware
