murchman
Dec 12, 2016Apprentice
New Firmware 1.4.0.18 released
Bug Fixes: Fixes the add-on satellite sync issue. Supports the NETGEAR Orbi app. http://kb.netgear.com/000036450/RBR50-RBS50-Firmware-Version-1-4-0-18
nlrela
Dec 16, 2016Guide
After the 2nd reboot I succeeded with the downgrade ... will test speeds this weekend
spewak
Dec 16, 2016Luminary
- murchmanDec 16, 2016Apprentice
Here are my test results from before and after the update conntected to the router and to the satalite. Not that it helps with your problem since mine is working without issue.
- spewakDec 16, 2016Luminary
nlrela,
That is wired. I updated the Firmware to the latest, enabled QOS to eliminate Buffer Bloat and voila. Lower Buffer Bloat is what I was after. Wireless speeds across devices (Apple and Android, Tablet and phone) both are about the same speed. Wireless speeds were never that fast until I purchased the Orbi.
