murchman
Dec 12, 2016Apprentice
New Firmware 1.4.0.18 released
Bug Fixes: Fixes the add-on satellite sync issue. Supports the NETGEAR Orbi app. http://kb.netgear.com/000036450/RBR50-RBS50-Firmware-Version-1-4-0-18
DarrenM
Dec 16, 2016Sr. NETGEAR Moderator
Hello nlrela
Thank you for testing this out I sent the issue over to engineering to try and replicate I may need to ask you some more info if you do not mind after I hear back from them.
DarrenM
nlrela
Dec 16, 2016Guide
OK thanks until now
- Dan_HDec 19, 2016Apprentice
I was under the impression that QoS is really going to limit bandwidth unless you have some serious processing power to handle it. I know on my router enabling QoS disables HW offload and I end up going from 300Mbps to roughly 60 Mbps. I know I am looking at this router with a 9 core procesor just to handle QoS and not lose speed https://routerboard.com/CCR1009-7G-1C-1SplusPC. So maybe turn off QoS and see if your speed comes back?
