murchman
Dec 12, 2016Apprentice
New Firmware 1.4.0.18 released
Bug Fixes: Fixes the add-on satellite sync issue. Supports the NETGEAR Orbi app. http://kb.netgear.com/000036450/RBR50-RBS50-Firmware-Version-1-4-0-18
Imthe0ne
Dec 28, 2016Guide
dethier1958,
I don't know if it is a typo or not, but I wouldn't recommend using the 192.128.x.x as an IP range. This is technially a public range, I would move it to a private range "192.168.x.x". In the off chance that you start coming across webpages that are hosted in the 192.128.x.x space, you would find yourself in a problematic situation of not being able to access those sites, as it is going to send you to your local addresses instead.
dethier1958
Dec 28, 2016Guide
Sorry, it was 192.168.1.250 ... and is now 192.168.1.251 and no repeat of the problem.
