ekhalil
Jul 11, 2019Master
New Firmware 2.3.5.30
Just updated my Orbi to 2.3.5.30. Seems stable so far. I see few "ads" for the Orbi app and links for app download in the web GUI. Otherwise I could not see much more new things. I'm keeping to loo...
ekhalil
Jul 11, 2019Master
The page that was called QoS under >> ADVANCED >> Setup is now called "Speed Test" as it should.
- pchiccino1Jul 11, 2019Aspirant
seeing config sync issue with this release as well, anyone else see this?
- FURRYe38Jul 11, 2019Guru - Experienced User
Is daisy chaing enabled or disabled?
Using combined SSIDs and not separate?
pchiccino1 wrote:seeing config sync issue with this release as well, anyone else see this?
no daisy chaing, and SSIDs are seperate however I have tried undoing that as well but issue continued.
- MishoAJul 15, 2019Tutor
same here
- Monti9901Jul 16, 2019Aspirant
Same issue as with every update. The update went fine, yet the speed was capped at 100mbps (i have 1gbps fiber). A factory reset and setup from scratch solved it.
