ekhalil
Jul 11, 2019Master
New Firmware 2.3.5.30
Just updated my Orbi to 2.3.5.30. Seems stable so far. I see few "ads" for the Orbi app and links for app download in the web GUI. Otherwise I could not see much more new things. I'm keeping to loo...
pchiccino1
Jul 11, 2019Aspirant
seeing config sync issue with this release as well, anyone else see this?
Jul 11, 2019Guru - Experienced User
Is daisy chaing enabled or disabled?
Using combined SSIDs and not separate?
pchiccino1 wrote:seeing config sync issue with this release as well, anyone else see this?
- pchiccino1Jul 11, 2019Aspirant
no daisy chaing, and SSIDs are seperate however I have tried undoing that as well but issue continued.
- FURRYe38Jul 11, 2019Guru - Experienced User
Try a factory reset on the system and setup from scratch. Give a few minutes for the system to settle in and check the condition. Clear out your browser caches too.
will give that a shot, thanks for the feedback
