ekhalil
Jul 11, 2019Master
New Firmware 2.3.5.30
Just updated my Orbi to 2.3.5.30. Seems stable so far. I see few "ads" for the Orbi app and links for app download in the web GUI. Otherwise I could not see much more new things. I'm keeping to loo...
clammerds
Jul 11, 2019Apprentice
The release notes from the interface tiself stop before they're finished (they don't even exist in the raw html) but here is what we can see :
Release Notes:
[Bug Fix] Fixes issues with the Apple HomeKit connectivity.
[Bug Fix] Fixes the wireless crash and reboot issue when the router is under stress.
[Bug Fix] Fixes the WiFi disconnection and IOT issue.
[Bug Fix] Fixes the guest isolation issue for multicast and broadcast traffic between the main host and guest.
[Bug Fix] Fixes the Ethernet backhaul boot-sequence issue.
[Bug Fix] Updates the OpenVPN certificate from MD5 to SHA-256.
[New Features and Enhancements] Circle Parental Controls support for India.
[New Features and Enhancements] Auto Time zone detection feature and setting.
[Bug Fixes] The client was not able to obtain an IP address when the router rebooted or the client renewed the IP address.
[Bug Fixes] The iOS speed test uploaded the throughput issue in PPPoE mode.
[Bug Fixes] Issues with the Japanese language string.
[Bug Fixes] The user wasnt able to log in to the GUI after finishing the GUI installation.
[Bug Fixes] The router GUI could not be accessed using oribilogin.com or orbilogin.net.
[Securi
I'm guessing this next one is a security fix. Anyway, already from the list, it's worth updating!
pablohoney
Jul 12, 2019Luminary
I tried updating my Orbi RBR 50 and RBS50. The status on the RBR50 is "Update failed" and the status on the RBS50 is "V2.3.5.30". How do I fix the "Update failed" issue?
- pablohoneyJul 12, 2019LuminaryIt seems to have fixed itself now.
