ekhalil
Jul 11, 2019Master
New Firmware 2.3.5.30
Just updated my Orbi to 2.3.5.30. Seems stable so far. I see few "ads" for the Orbi app and links for app download in the web GUI. Otherwise I could not see much more new things. I'm keeping to loo...
Retired_Member
Jul 12, 2019I don't do manual updates.
Does this update qualify as a 'auto' update?
CrimpOn
Jul 12, 2019Guru - Experienced User
Retired_Member wrote:I don't do manual updates.
I did it via the Auto Update page on the web interface.
- Retired_MemberJul 12, 2019
Thanks
I'm wondering if this update qualifies for a NG push?
I was told by the NG support folks that the only updates that will be pushed are those with with major changes. Others are at the users preference.
- pablohoneyJul 12, 2019LuminaryAfter every firmware update I lose wifi calling on my iPhone XS Max. Is it port triggering or port forwarding that needs to be used if one is having issues with Wifi Calling? Anyone else have the same issue?
- FURRYe38Jul 12, 2019Guru - Experienced User
Does the wifi calling work after you reboot the RBR and RBS? Try a factory reset and setup from scratch and try wifi calling again?
