ekhalil
Jul 11, 2019Master
New Firmware 2.3.5.30
Just updated my Orbi to 2.3.5.30. Seems stable so far. I see few "ads" for the Orbi app and links for app download in the web GUI. Otherwise I could not see much more new things. I'm keeping to loo...
ekhalil
Jul 12, 2019Master
pablohoney wrote:
After every firmware update I lose wifi calling on my iPhone XS Max. Is it port triggering or port forwarding that needs to be used if one is having issues with Wifi Calling? Anyone else have the same issue?
If you set the phone to Flight Mode, does Wifi Calling kick in then?
CrimpOn
Jul 12, 2019Guru - Experienced User
Maybe there is a terminology issue? When I set my phone to "Airplane mode", Bluetooth, WiFi, and Cellular all turn off. Only NFC remains on. No WiFi = no WiFi calling.
- ekhalilJul 12, 2019Master
CrimpOn wrote:Maybe there is a terminology issue? When I set my phone to "Airplane mode", Bluetooth, WiFi, and Cellular all turn off. Only NFC remains on. No WiFi = no WiFi calling.
Correct, but after setting the phone to Airplane Mode, you you be able to enable Wifi.
In iPhone Wifi will stay on after setting the phone into Airplane Mode.
- CrimpOnJul 12, 2019Guru - Experienced User
Fascinating, "Airplane Mode" is a short-cut that turns off radios, but does not keep them off.
Learn something every day. Thanks!
- bobluckJul 12, 2019Initiate
Guess it's possible to make the web interface suck more. Just proved it by placing ads in it.
