ekhalil
Jul 11, 2019Master
New Firmware 2.3.5.30
Just updated my Orbi to 2.3.5.30. Seems stable so far. I see few "ads" for the Orbi app and links for app download in the web GUI. Otherwise I could not see much more new things. I'm keeping to loo...
chuydv
Jul 13, 2019Aspirant
I updated the firmware through the app and seems to connect fine to the internet, but (there is always a but)... now I am unable to connect to the Orbi App and the only way is to access remotely. Additionally my wired conection to Orbi is not recognized and connects it automatically to my spectrum modem, so I cannot access to routerlogin.com.
Does anyone have seen this? I hate to reset and connect again 20+ devices again. Ugh
Jul 13, 2019Guru - Experienced User
Try orbilogin.com for Orbi web page.
chuydv wrote:I updated the firmware through the app and seems to connect fine to the internet, but (there is always a but)... now I am unable to connect to the Orbi App and the only way is to access remotely. Additionally my wired conection to Orbi is not recognized and connects it automatically to my spectrum modem, so I cannot access to routerlogin.com.
- Chp66Jul 13, 2019AspirantUpdated firmware manually through the iOS app. WiFi was dropping on and off. Did factory reset on router and satellites. WiFi still continues to drop and come back up. No problems before update.
- Chp66Jul 13, 2019AspirantI downgraded the firmware to 2.3.1.58. Problem has been corrected. WiFi not dropping any more.
- chuydvJul 13, 2019Aspirant
I have a Orbi RBR40 connected to a Wave 2 - RAC2V1S Sagemcom
The cable modem is an Ubee eMTA , Model: E31_2V1
I have it connected the Orbi to the Spectrum Router because when I got this new modem/router from spectrum it didn't work directly Orbi with the Cable Modem.
FURRYe38 wrote:What is the Mfr and model# of the ISP modem the NG router is connected too?
- FURRYe38Jul 13, 2019Guru - Experienced User
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
chuydv wrote:I have a Orbi RBR40 connected to a Wave 2 - RAC2V1S Sagemcom
- ekhalilJul 14, 2019Master
I downgraded today to 2.3.1.60.
This is the first time that I downgrade to a previous release, but I could not find any other way, unfortunately!
