ekhalil
Jul 11, 2019Master
New Firmware 2.3.5.30
Just updated my Orbi to 2.3.5.30. Seems stable so far. I see few "ads" for the Orbi app and links for app download in the web GUI. Otherwise I could not see much more new things. I'm keeping to loo...
Jul 13, 2019Guru - Experienced User
Try orbilogin.com for Orbi web page.
chuydv wrote:I updated the firmware through the app and seems to connect fine to the internet, but (there is always a but)... now I am unable to connect to the Orbi App and the only way is to access remotely. Additionally my wired conection to Orbi is not recognized and connects it automatically to my spectrum modem, so I cannot access to routerlogin.com.
Does anyone have seen this? I hate to reset and connect again 20+ devices again. Ugh
Chp66
Jul 13, 2019Aspirant
Updated firmware manually through the iOS app. WiFi was dropping on and off. Did factory reset on router and satellites. WiFi still continues to drop and come back up. No problems before update.
- Chp66Jul 13, 2019AspirantI downgraded the firmware to 2.3.1.58. Problem has been corrected. WiFi not dropping any more.
- FURRYe38Jul 13, 2019Guru - Experienced User
Next time, try a factory reset after upgrading FW to see if the problem continues before downgrading FW.
Having no problems here...
Chp66 wrote:
I downgraded the firmware to 2.3.1.58. Problem has been corrected. WiFi not dropping any more.- Chp66Jul 14, 2019AspirantI did a factory upgrade on the router and satellites after noticing the problems, but the issues persisted. Only then did I downgrade. No issues since then. Thanks
