ekhalil
Jul 11, 2019Master
New Firmware 2.3.5.30
Just updated my Orbi to 2.3.5.30. Seems stable so far. I see few "ads" for the Orbi app and links for app download in the web GUI. Otherwise I could not see much more new things. I'm keeping to loo...
Swimmer63
Jul 14, 2019Aspirant
I have an RBR50 with two RBS50 Satelites. I went to check if I needed a firmware update. iOS app always says no. So I logged into the RBR50 UI on my phone. Sure enough it set an update was needed. I hit update and waited.
When I restarted the UI I had version V2.3.5.30. I could not remember if that's what I had or not. So I tried logging into netgear.com.
After 30 minutes of trying to log in, including changing my password twice I gave up and just started browsing support.
In support it showed the current update as being V2.3.1.60. No where could I find anything higher than this version. Am I dense? Why do I have firmware that's a number of iterations past what is listed on the website?
Jul 15, 2019Guru - Experienced User
Try a factory reset on the RBR and setup from scratch.
Swimmer63 wrote:I have an RBR50 with two RBS50 Satelites. I went to check if I needed a firmware update. iOS app always says no. So I logged into the RBR50 UI on my phone. Sure enough it set an update was needed. I hit update and waited.
