ekhalil
Jul 11, 2019Master
New Firmware 2.3.5.30
Just updated my Orbi to 2.3.5.30. Seems stable so far. I see few "ads" for the Orbi app and links for app download in the web GUI. Otherwise I could not see much more new things. I'm keeping to loo...
alghawi
Jul 16, 2019Aspirant
ok just bought new one. updated via app. everything is fine. but lost internet connection after 20min. tried everything still the issue prisist. the only solution right now is to turn the router off and on again. any fix
- FURRYe38Jul 16, 2019Guru - Experienced User
Hard to tell. New systems usually come with old FW and there is a couple of intermediate builds that have to be applied first before setting to the latest. Possible that the system was doing this and eventually got updated however needed a power cycle to clear it all out.
Is the system working now after the power cycle? If not, try a factory reset on the RBR and power OFF the ISP modem for 30 seconds then back on then walk thru the setup wizard with a wired PC with the RBR...
alghawi wrote:
ok just bought new one. updated via app. everything is fine. but lost internet connection after 20min. tried everything still the issue prisist. the only solution right now is to turn the router off and on again. any fix- alghawiJul 17, 2019AspirantHi ty for the reply.
I'm not sure what happened. Its now working fine and no issue.
The only thing I remember doing is shutting down my other Netgear xr700 that was connected to it and I went to sleep. Woke up and orbi was working fine.
When I go back home I will switch on xr700 and see if it has anything to do with orbi internet disconnection- Monti9901Jul 17, 2019Aspirant
Even after a full factory reset i am still having issues the wifi. It keeps going on and off, the devices are losing, then coming back, every 1-2mins. It's all default, apart from the WiFi name. Any ideas? This happens even without the satellites being on.
- ekhalilJul 17, 2019Master
alghawi wrote:
ok just bought new one. updated via app. everything is fine. but lost internet connection after 20min. tried everything still the issue prisist. the only solution right now is to turn the router off and on again. any fixalghawi When this happens, does the Router's top LED turn magenta? Also can you please check the ISP Lease time in the web GUI under >> ADVANCED >> ADVANCED Home >> CONNECTION STATUS >> and check the displayed Lease Obtained and Lease Expires values when this issue happens
No light on top of the router.
- CrimpOnJul 17, 2019Guru - Experienced User
alghawi wrote:No light on top of the router.
This may not be relevant, but I had a mysterious experience with Spectrum cable this week. I noticed web pages not loading and looked over at the Spectrum modem. The "Online" LED was white instead of blue. My phone switches from WiFi to LTE and a web search turned up an outage in several nearby cities (including mine).
The goofy part is that the Orbi ring never showed anything. No magenta. No flashing. Nothing! My hypotheses is that (a) the Orbi had an IP address already from the modem, and (b) the ethernet connection between the two was still up, so the Orbi was "just waiting." (for about an hour as it turned out).
I have no solution for your problem, except that we cannot count on the Orbi to "turn red" when something is wrong with the internet connection.
