ekhalil
Jul 11, 2019Master
New Firmware 2.3.5.30
Just updated my Orbi to 2.3.5.30. Seems stable so far. I see few "ads" for the Orbi app and links for app download in the web GUI. Otherwise I could not see much more new things. I'm keeping to loo...
gr8sho
Aug 05, 2019Virtuoso
ekhalil wrote:
I did NOT do factory reset for the Router. I only did reset for the Satellite to remove the wireless backhaul sync.
Great. I don't use wired backhaul so a standard update should work.
pablohoney
Aug 08, 2019Luminary
I'm noticing a connection drop with the Orbi satellite of a few seconds then it reconnects but what this causes is my “legacy” devices i.e. Ring Floodlight Cam, Ring Spotlight Cam Mount and Bowers and Wilkins A7 wireless speaker, LG E8 OLED to connect to the main Orbi router in a different room.
Anyone else noticing this temporary connection drop with the Orbi satellite since the latest firmware update? If so can you please report it to Netgear so it’s taken seriously and fixed.
Thanks
Thanks
