ekhalil
Jul 11, 2019Master
New Firmware 2.3.5.30
Just updated my Orbi to 2.3.5.30. Seems stable so far. I see few "ads" for the Orbi app and links for app download in the web GUI. Otherwise I could not see much more new things. I'm keeping to loo...
NetNoob777
Aug 11, 2019Initiate
Hi All
I have read through the 160+ post under this new version 2.3.5.30 version
So the story being when I bought the ORBI RBK50 on 9th Aug 2019. Plugged it all up and left he firmware update to 2.3.5.30 no issue there for RBR or RBS
Work well for 24+ day and the reboots start happening on the Sunday morning and ever since. I found at first that I notice it was 3 time with in 12 hour period.
Then I was doing more monitoring the reboots would be between 20min intervals to it running up to 12 hours.
RBR50 – 1 network cable from the modem\router to the Ewan port on the back
RBS50 – has 4 Ethernet connection to devices
1st configuration I tried and want to use.
Modem Billion 7800NXL – Wireless turn off but router left active as I want it that was.
Orbi RBR50 – wired direct to the modem port 1.
set in to AP Mode
With these change set
- SSID Name,
- Wifi Password,
- 2.4ghz set to channel 8 (1 used for Sonos, 6 & 11 to many in my neighbourhood)
Note: The sonos boost is connect directly to port 2 on my modem Channel 1. The sonos works perfectly no drop out or issue when the orbi reboots
After 3 days had enough and Downgrade to FW 2.3.1.60 to see if the original firmware had the same issue out of the box, this time the following 2 configs were used.
2nd configuration
Modem config same as above
Orbi RBR50 and RBS50 both factory reset.
- Left the RBR50 as router mode this time.
- SSID Name,
- Wifi Password,
- 2.4ghz left to Auto this time as I forgot to change it
- Daisy chain – turn it off (after reading it on this forum)
Ran for 12+ hours without any reboots.
3rd configuration
Without factory reset 2nd config I just change it from router mode to AP mode worked great for 3 hours then reboot started
3hours, 45min, 1hr and 45min And so on.
So then on tops of 2nd config I change
- 2.4ghz to channel 8
- 20/40hz coexistence – turn it off (after reading it on this forum)
- Also turn off the RBS50 which has a few thing connected via Ethernet as I read some people found there RBS50 with Ethernet attached devices were causing issue.
I haven’t turn off\unplugged all my sonos because I don’t see how they would be affecting the RBR50 as they are not plugged in to it.
I have been thinking of upgrading again to 2.3.5.30 to see if it make any differences as I did see one of the bug fixed in that first wear was to fix the random reboots. But as you can see I was getting them with my first configuration
Any other thought recommendations would be great. If I don’t get a resolution by this weekend or early next week I have been told by the store I can return it.
Just have to look for another solution if it is the velop or something else.
- NetNoob777Aug 18, 2019Initiate
NetNoob777 wrote:Hi All
Then I was doing more monitoring the reboots would be between 20min intervals to it running up to 12 hours.RBR50 – 1 network cable from the modem\router to the Ewan port on the back
RBS50 – has 4 Ethernet connection to devices1st configuration I tried and want to use.
set in to AP Mode
- SSID Name,
- Wifi Password,
- 2.4ghz set to channel 8 (1 used for Sonos, 6 & 11 to many in my neighbourhood)Note: The sonos boost is connect directly to port 2 on my modem Channel 1. The sonos works perfectly no drop out or issue when the orbi reboots
2nd configuration
- SSID Name,
- Wifi Password,
- Daisy chain – turn it off (after reading it on this forum)Ran for 12+ hours without any reboots.
3rd configuration
- Also turn off the RBS50 which has a few thing connected via Ethernet as I read some people found there RBS50 with Ethernet attached devices were causing issue.I haven’t turn off\unplugged all my sonos because I don’t see how they would be affecting the RBR50 as they are not plugged in to it.
Well I had enough last wednesday. I spent tuesday night configuring all my router setting in to the orbi and set my Billion 7800nxl to Bridge mode then did some testing of routers and then went to bed.Wednesday woke up a check up time of the router and it say 36min which is telling me it had reboot during the night. Two hours later reboot again. So after that I had enought the Orbi it would reboot in AP or Router Mode so factory reset and back to ththe shop I bought it from and swapped it for Linksys Velop Tri-band. went home hookup it up set to AP mode, configured the nodes and then put them in the correct location around the house. Then did a rescan on the channels to make sure they are optimized and been running sold ever since.
Orbi would be a great product if it just worked.
