ekhalil
Jul 11, 2019Master
New Firmware 2.3.5.30
Just updated my Orbi to 2.3.5.30. Seems stable so far. I see few "ads" for the Orbi app and links for app download in the web GUI. Otherwise I could not see much more new things. I'm keeping to loo...
groupjdesign
Aug 23, 2019Aspirant
I never saw anything other than the Speed Test in that tab. Is there something else in that window?
OKinNJ
Not sure what window you may be referring to. Using orbilogin.net, there is a (download and upload) speed test. If you use the Orbi app (iOS in my case), and open the device manager (or click on each router or satellite in network view), you will see a reported link rate for each connected client device (just touch each item to open it up and see this info). Note that this "rate" tells you rather little about your actual performance with actual applications (other than you can't get a file transfer speed test of 200 Mbps if the link rate is 72 Mbps, for example).
Not sure if this helps :smileyhappy:
