ekhalil
Jul 11, 2019Master
New Firmware 2.3.5.30
Just updated my Orbi to 2.3.5.30. Seems stable so far. I see few "ads" for the Orbi app and links for app download in the web GUI. Otherwise I could not see much more new things. I'm keeping to loo...
Retired_Member
Oct 14, 2019
triak wrote:Firmware 2.3.5.30 is an absoolute disaster.
Just curious.....did you do the FW update manually or was it performed auto-update?
AFD
Oct 14, 2019Luminary
I didn't perform any action from my side to perform the update . I assume it was an auto update .
It's a disaster , also WiFi is unstable . Let's see if I have some time today to rollback . For the moment, status is : all the devices connected to the main router with the mentioned problems .
- Retired_MemberOct 14, 2019
It's a disaster , also WiFi is unstable . Let's see if I have some time today to rollback . For the moment, status is : all the devices connected to the main router with the mentioned problems .Do you have another router in your network?
- AFDOct 14, 2019LuminaryTo the question if I have another router in my network . Answer is no . I don't have any router in my network just the Orbi System .
- AFDOct 16, 2019Luminary
Start testing with the following Steps
1 - Start disconnection (turn off-on) of each device thta supposed to be connected to the satellite (more than 20 devices)
2 - Verify the connections
3 - Depending on the results 1-2 go to factory reset and reinstall 2.3.1.44 (manually)
4 - Restore the previously config file saved 2 months ago .
Thanks for all the collaboration and support . Im going to keep you informed about the results
By the way , it seems that unstable wifi is better now (I dont know why , because I didn't perform any action , but let's see)
- AFDOct 17, 2019Luminary
Problem solved(??) for the moment , status follows
This is the Method I used in my case
1 - Factory reset
2 - Manual installation Firmware 2.3.1.44
3 - Load Configuration file from Backup
4 - Testing everything with old firmware (OK)
5 - Manual installation Firmware 2.3.5.30
6 - Turn OFF/ON all the devices that supposed to be connected to the satellite
7 - Testing everything since 2 hours ago (seems to be ok)
Let's see what happen . Firmware 2.3.5.30 (up and running) .
- FURRYe38Oct 17, 2019Guru - Experienced User
Keep us posted on how it goes. A factory reset seems to help resolve some issues. Also manual load of FW files is good too.
