ekhalil
Jul 11, 2019Master
New Firmware 2.3.5.30
Just updated my Orbi to 2.3.5.30. Seems stable so far. I see few "ads" for the Orbi app and links for app download in the web GUI. Otherwise I could not see much more new things. I'm keeping to loo...
MishoA
Oct 16, 2019Tutor
FURRYe38 I have a question for you. I noticed you have a lot of experience with the ORBI and your advise would be much appreciated.
I have an ORBI RBR50 with one satelite RBS50
I have followed your suggestions from other posts disabled Daisy chain, set it to 40hz only, MIMO and so on. It works great without disconnects perfectly, except when my ISP goes down and then back up. That disconnects start all over. When I send out a ping through command prompt lets say ping www.ibm.com -t.. After lets say the 10th try, the ping would either go above 1000ms or straight up Request Time out and then back to normal and after few more pings does the same thing. Now the only way I have found for it to work is if I turn off my modem, router and sat, and then turn on the modem, wait till I get a couple of lights out of 4, turn on the rbr50, wait till it turns on and start blinking as if it is trying to sync and then turn on the satallite. If I don't follow it through exactly, I have to redo it all over again. Any suggestions?
P.S I have done factory reset and it works until the power goes out or the ISP is having issues and it does it all over again
Oct 16, 2019Guru - Experienced User
What is the Manufacturer and model of the ISP modem? Built in router here or stand alone modem only?
Kind of sounds like the ISP service line needs to be looked into.
I would download pingplotter.com and install on a wired PC. Connect it directly to the ISP Modem with out the RBR online. Run some plots to pingplotter.com and let it run for a while if you can. See if it picks up any errors or Pack Loss along the way.
Ensure your ISP as checked the service line up to the ISP Modem.
If a cable modem, be sure to use good quality RG6 coax cabling.
Ensure there are no coax cable line splitters between the ISP service box and the modem.
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
MishoA wrote:FURRYe38 I have a question for you. I noticed you have a lot of experience with the ORBI and your advise would be much appreciated.
- MishoAOct 16, 2019Tutor
I have Spectrum 400mbps package,using my own cable modem, Netgear CM500, and it worked without any issues when I used it with my NETGEAR Nighthawk X4S - AC2600. I had to replace it because of the range. Definitely the range between the rbr50 and rbs50 is about 30 feet or slightly more and the sq footage of the house is about 3150. I tried setting the channel to 1, 6 and 11 for the 2.4 ghz for the wireless devices but the thing is that I am plugged in directly to my satellite with an ethernet cable and was seeing the disconnects. I will do as you suggest connecting directly to the modem and try out pingplotter. Also, definitely no splitters or anything like that.
- FURRYe38Oct 16, 2019Guru - Experienced User
Are you seeing problems with a wired PC connected to the RBR?
MishoA wrote:I have Spectrum 400mbps package,using my own cable modem, Netgear CM500, and it worked without any issues when I used it with my NETGEAR Nighthawk X4S - AC2600. I had to replace it because of the range. Definitely the range between the rbr50 and rbs50 is about 30 feet or slightly more and the sq footage of the house is about 3150. I tried setting the channel to 1, 6 and 11 for the 2.4 ghz for the wireless devices but the thing is that I am plugged in directly to my satellite with an ethernet cable and was seeing the disconnects. I will do as you suggest connecting directly to the modem and try out pingplotter. Also, definitely no splitters or anything like that.
- MishoAOct 17, 2019Tutor
Since I did the steps I mentioned in my earlier post, it has been stable and haven't seen any issues. Unfortunately, I was so annoyed and forgot to do the obvious and connect to the RBR directly. When the that occurs again, I will defintely do that first and let you know. Thanks for the advice!
