ekhalil
Jul 11, 2019Master
New Firmware 2.3.5.30
Just updated my Orbi to 2.3.5.30. Seems stable so far. I see few "ads" for the Orbi app and links for app download in the web GUI. Otherwise I could not see much more new things. I'm keeping to loo...
kyleb88
Oct 21, 2019Guide
Firmware V2.5.0.38 out on my orbi. Helpfully this fixes all the issures I have with dropped connections and reboots.
- FURRYe38Oct 21, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
kyleb88 wrote:Firmware V2.5.0.38 out on my orbi. Helpfully this fixes all the issures I have with dropped connections and reboots.
- larryindublinOct 21, 2019Luminary
Current Version: V2.3.5.30 New Version: V2.5.0.38 Release Notes:
[Bug Fix] Fixes issues with the Apple HomeKit connectivity. [Bug Fix] Fixes the wireless crash and reboot issue when the router is under stress. [Bug Fix] Fixes the WiFi disconnection and IOT issue. [Bug Fix] Fixes the guest isolation issue for multicast and broadcast traffic between the main host and guest. [Bug Fix] Fixes the Ethernet backhaul boot-sequence issue. [Bug Fix] Updates the OpenVPN certificate from MD5 to SHA-256.
[New Features and Enhancements] Enhances the device recognition mechanism of the attached devices list.
[Bug Fixes] Fixes the compatibility issue with Sonos devices.- FURRYe38Oct 21, 2019Guru - Experienced User
For any v.38 version information and experiences, please post here:
Thanks.
