ekhalil
Jul 11, 2019Master
New Firmware 2.3.5.30
Just updated my Orbi to 2.3.5.30. Seems stable so far. I see few "ads" for the Orbi app and links for app download in the web GUI. Otherwise I could not see much more new things. I'm keeping to loo...
kyleb88
Oct 21, 2019Guide
Firmware V2.5.0.38 out on my orbi. Helpfully this fixes all the issures I have with dropped connections and reboots.
Oct 21, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
kyleb88 wrote:Firmware V2.5.0.38 out on my orbi. Helpfully this fixes all the issures I have with dropped connections and reboots.
