jeberhawk
Jan 19, 2025Tutor
New Firmware for RBR50v2, but Low Armor Security Score on Home Network!
I have an Orbi RBR50v2 with three satellites. Since I purchased the system in 2019, I have not had many problems. I'll eventually update the firmware of the mesh network for my home. I'm happy I noti...
Jan 20, 2025Guru - Experienced User
The scoring is pretty dumb. Yes, it takes off points for "not having armor" on devices it could be installed on. It also takes points off if you even shut off armor. I'm testing armor right now and my score dropped from 90 to 53 just by shutting it off for a day for a test. Then it came back up to 73 but stayed low because it had been shut off. Usually there's an area to click that shows why its low. I wouldn't worry about it to much as the pointing system has some magic formula it uses they don't tell us about.
- jeberhawkJan 20, 2025Tutor
The scoring is a marketing ploy to encourage users to purchase Armor software for every device on my network. As you did, I could shut down Armor to see if the percentages change.
Which model of Orbi do you have? I'm considering upgrading to later models, but Netgear is damn proud of its mesh network products! Considering the price points, I may look at other manufacturers.
One last question. At one time Netgear posted firmware updates for my Orbi system: Download Center | Downloads and Documentation | NETGEAR But what's interesting is the mobile app shows an update to version 2.7.5.6? Does Netgear expect me to update via the mobile app?
- plemansJan 21, 2025Guru - Experienced User
The newer firmware was just released recently. Usually, it's a phased rollout. It's just security updates. I'm not a fan of the app update, but I've heard it's gotten better. I'd either do it manually or through the browser.
What speeds do you pay for and get from your ISP?
I see a lot of people who "need" to upgrade but have fairly slow service and won't see a whole lot of benefit.Versus those with 1 gig plans, should upgrade.
I'm a fan of renewed devices. There have been quite a few on the old Jeff Bezos site for mesh systems.
- jeberhawkJan 21, 2025TutorI have Gfiber, 1 gig, for $70/month.
