Random12
Jun 19, 2017Apprentice
New firmware released 1.11.0.20
Some people were saying the 1.11.0.N beta was helping with a lot of issues. There is a new version released, but the release notes don't list any fixes. Has anybody tried the new version to see if it...
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
ktd
Good thing I’m on a business trip and didn’t have time to update. :)
AmitR
Jun 19, 2017NETGEAR Employee Retired
We released this firmware release to target some wireless connectivity issues on the RBR40 related SKUs (RBK40, RBK43, RBK30, etc), including the Macbook issue. As a reminder, we continuously to work to improve the wireless connectivity and performance and fix bugs that are brought to our attention.
Orbi Product Team
- superben79Jun 19, 2017Apprentice
this is all i see in readme
Bug Fixes:
- Firmware version sync up.
none of the fixes you mentioned.
- DarrenMJun 21, 2017Sr. NETGEAR Moderator
Hello Flash008
orbi should not auto update to the live firmware if you are on the beta since it is version 1.11.0.80 which is higher than current firmware.
DarrenM
- wchpJun 21, 2017Luminary
DarrenM,
So... even though the image file says RBR/RBS50-V1.11.0.8 it is actually x.x.x.80?
Just want to confirm, as I loaded .8 beta as provided by Netgear support 2 days ago, did a hard reset on both the satellites and router and then manually reconfigured everything again from scratch.
I did not load the prior saved config...
but I would hate to have it auto-update to .20 as I don't have a saved config for .8(0?) and it's a pain to do 12 DHCP reservations and reenter all the proper device names in the attached devices table.
Thanks for the assistance to date.
