MattHopkins
Jan 04, 2017Guide
New firmware so much better (1.4.0.34)
Just wanted to let you guys / others know that the latest firmware (34) has solved so many of my problems. I no longer seem to get connection drops on my Apple products (my MacBook Air would lose the...
jmbarbs
Jan 05, 2017Apprentice
Updated this morning to latest version 1.4.0.34 and no ios disconnections for a hour. Started dropping again multiple times since. Also still have disconnection issues with Nest cams if beamforming option turned on, post update. Logged again with Netgear support and was advised that 1.4.0.34 is supposed to have fixed the IOS issue and tech support suggested i reset the orbi system and re-run setup again. With regards to the nest cams, she said this hasn't been proven to be a fault with Orbi yet?
Anyone else having issues since new firmware, and if so has a factory reset made any difference ? I have advised tech support will reset and report back if not resolved
- Hydro130Jan 05, 2017Luminary
I have multiple iOS devices in my house (all running latest f/w), and have never had any connection problems at all with this latest Orbi f/w or any previous versions of the Orbi f/w.
I don't have Nest cams, so I can't comment on that.
- jmbarbsJan 05, 2017Apprentice
Since having issues with latest update on orbi with iOS devices dropping wifi, I reset network settings in iPad Pro and then reconnected to wifi network and have had zero disconnections in last 3 hours, which is significant improvement.
- Michael74Jan 06, 2017Guide
Hi,
I am facing also disconnects for our iPads (Air 1 and a 9.7 pro, both latest iOS).
I downgraded from .18 to .16 which made no difference, still disconnects.
Upgrade to .34 did not solve the issue either, still disconnects.
Beamforming and MU-Mimo activated.
I have not yet done a reset but will try that later.
BR
Michael
