MattHopkins
Jan 04, 2017Guide
New firmware so much better (1.4.0.34)
Just wanted to let you guys / others know that the latest firmware (34) has solved so many of my problems. I no longer seem to get connection drops on my Apple products (my MacBook Air would lose the...
bfeltovi
Jan 05, 2017Aspirant
Do updates need to be applied sequentially or can I just skip to the latest?
TC_in_Montana
Jan 05, 2017Virtuoso
You do not have to update sequentially. You can skip any intermediate ones and go to the latest.
Please remember to update your satellite(s) first, then your router. And do not try and do them at the same exact time.
- AndUrbiJan 15, 2017Guide
TC_in_Montana wrote:You do not have to update sequentially. You can skip any intermediate ones and go to the latest.
[emphasis added]
That part is very important. It would also be a lot easier if Netgear replaced the single "Update All" button with individual Update buttons next to each unit in the network. Most users are just going to click the Update All shotgun button.
- Michael74Jan 15, 2017Guide
Hi,
just recognized that the procedure you described is mentioned by Netgear as well. Why they incorporated an update all button
is then a secret which only Netgear knows...*facepalm*
I updated till 0.34 always both at the same time since I was not aware of another
recommendation.
What if users HAVE updated both at the same time?
Do we need to reset the system or anything else to do?
An answer from Netgear support / mods would be very helpful.
BR
Michael
Michael74 wrote:What if users HAVE updated both at the same time?
I expect the recommendation for one-at-a-time is so that if something goes wrong with a satellite, your primary router is still working and you can debug a single problem at a time.
