MattHopkins
Jan 04, 2017Guide
New firmware so much better (1.4.0.34)
Just wanted to let you guys / others know that the latest firmware (34) has solved so many of my problems. I no longer seem to get connection drops on my Apple products (my MacBook Air would lose the...
Rustproofcorn
Jan 06, 2017Luminary
Have u tried only enabling the mimo? The only beamforming your able to enable is implicit which is for N devices. And explicit might work with any N devices u have anyhow. But I'd all your devices are ac then u don't need it anyhow. I'm assuming your nest devices are N? I would see if there are issues with them with implicit beamforming off.
Michael74
Jan 06, 2017Guide
Hi rustproofcorn,
food point regarding Beamforming, I will disable it and check whether the disconnects will stop.
BR
Michael
- Retired_MemberJan 06, 2017
I have android disconnecting, but no IOS issues and our house has mostly IOS devices.
- Jako888Jan 07, 2017Star
Installed .34 yesterday.
Still having iOS drop outs. Netgear really need to get this sorted. How hard can it be to test to make sure it works instead of releasing another firmware and cross fingers?
- Michael74Jan 07, 2017Guide
Hi,
short update from my end.
I am still on .34 and disabled Beamforming. Since then I recognized just one disconnect.
Anyhow, I totally agree with Jako888, Netgear has to get that fixed!
Has anybody tried the reset?
BR
Michael
